Hello,
I thought that any SD card (up to 16GB) would work, but with stock Android Eclair 2.1 I had no luck with the following: Kingston microSD SDHC 8GB, Class 4.
dmesg shows the following error: "mmc0: error -110 whilst initialising SD card".
The card works flawlessly in a BlackBerry Curve 8520 and in a netbook with the SD adapter.
The Kyros SD reader works fine with a 2GB microSD card.
Tested also with Android GingerBread 2.3.1 and no luck either, same problem.
