Problem With 9" Pandigital Novel Connecting To WiFi
Mitch1950
I am having a problem connecting to my home WiFi with my 9" Pandigital Novel. It can take over 1 hour before it will connect. Most of the time when I tap on my remembered network it comes back to show WiFi "Disconnected" HELP!!!!!! ANYONE PLEASE!!!!!!!
I just did a factory reset on mine a planet and it gave me some grief logging in it's only 3 feet away lol, double check
your router code you input, settings etc maybe reboot the router! check all the basic stuff first! worked on mine good luck
