Problem With Booting
Karibes
10
Hello,
I have made bootable SD for CM7 and it worked until now. Somehow it doesn't boot anymore, it is stucked while loading blue screen android with dot and never loads to OS Android.... I tried everything, but problem is still same.... Need a help :(
P.s: it is solved. Sorry for disturbing.
Please post what you did to fix the issue so that the next person that comes along with the same issue will know what to do. Thanks!
Yo,
Well, I removed mSD out and mounted back, then it worked. I can guess that nook didn't recognize it.
Take care
