Problem with movies playing out of order on 7024
maddenr2
Hello all,
I use DVD Decrypter to rip, Handbrake to encode, and movies play perfectly fine on my computer. When I transfer them to my Coby 7024, the chapers are all out of order, looks like they add +1 hour to some of the beginning ones, so what should be playing at 00:00:01, plays at 01:00:01.
I've tried three different players: Gallery, Mplayer, and Real Player beta.
Any ideas?
Thanks in advance!
Sorry, I'm going to add a bit more because I was confused by what my wife was saying. The movies play FINE and in order, but when you try to skip to a certain part, then the order gets all jumbled up and will put stuff that should be at the beginning of the movie towards the middle, that's when the hour jump thing happens. Hope that was clear-ish.
I'm using WinDVD to convert DVDs to .mp4. I'm having the same issues. When skipping to different parts of the movie, it jumps to different parts of the movie that are out of order. I was thinking of trying .avi to see if the same thing happens.
Anyone have a solution out there?
James
