Problems mounting the SDcard after manual ROM upgrade
vizo
21
Hi,
I had been using the 0714 ROM for sometime without any problems, but decided to flash to nightly 177 AND.
1- The ROM Manager did not work (Question asked in another post)
2- I downloaded the nightly, and flashed it from the SD card.
Now, all my applications and everything is gone. I went to the market and dloded Titanium with the hope that I could restore from my previous backup, but Ti BUP says ext storage is not mounted.
I booted to recovery and tried to mount sdcard through mounts menu, but I cannot mount it from there too.
When I check the file manager, I see the sd icon, but the folder is empty.
I need help.....
Go into "settings" and select "storage", look in there for your SD card and there you should be able to mount it although I'm not sure why it didn't automatically mount it after reboot.
