Hi,
This is first table review at all. Thx for your tolerance and more important for your constructive comments.
Ramos W17 Pro 7" Android Tablet PC
Specifications
Measurement
The dimension of Ramos W17 PRO is 197*113.5*10.5mm along with the weight of 290g only, which is quite portable. Of course a 7” diagonal screen is not a 10” one but it has the advantage to be more portable especially because of the thinness and the pocket book size.
Screen
Ramos W17 PRO sports 7 inch LCD display with resolutions 1024*600. The images are vivid and bright. Although Ramos W17 PRO does not come with an IPS display, we still can find the photographs are crystal and life-like.
Operating System and Hardware Information
Ramos W17 PRO got a fast speed on turn-on and turn-off. The CPU running at 1.2Ghz (without overclocking) drop to 97Mhz on this standby mode. Operating system of Ramos W17 PRO is Android 4.0.3. UI is the standard pattern of Ice cream Sandwich system. Ramos W17 PRO supports 802.11b/g/n WiFi and 3G dongle. The steady and strength of WiFi is quite good. Being separate by a wall and a distance for 7 meters, it can still find the signal.
Web
Here the Dual-Core choices of Ramos take all his meaning. The flash website are really smooth and speedy. Expecting that is due of the Amlogic AML8726-MX CPU, this CPU has the the authorized flash decoding technology and it supports website viewing GPU acceleration. Ramos W17 PRO took only 8 seconds to load the site while the single core device need 20 seconds due to the flash plug-ins.
Playing Videos
Because the traditional design of Amlogic series platform, playing the online video will occupy the local player which makes the video have a speed loading and a smooth play.
Amlogic has very professional experiences in video decoding. In the processor AML8726-MX, there are two video DSP decoding decoders which have an excellent decoding ability in different formats (based on Amlogic website). The chip supports 3D video decoding and it can adjust the light, contrast automatically.
Gaming Test
Ramos W17 PRO has very good performance with its sensitive G-sensor and speed CPU. Ramos W17 PRO showed a great compatible and outstanding run-on during the test. For some single core devices, the resolutions and GPU cannot reach the demand of gaming lovers. With the dual core CPU and dual core GPU, Ramos W17 PRO has achieved a great progress in these sides. Ramos W17 PRO also can be rooted with Chainfire3D plug-in with which the device is able to improve the compatible.
Power and Battery Life
First day, tablet has been turn on at 23:02 with the battery 48%, and the second day the battery decreased to 44%. That is, the device took 4% power consumption for nearly 9 hours. The reason is that the frequency will down to 96MHz automatically when it’s stand-by.
A Video review:
Specifications
OS | Android 4.0.3 |
CPU | AMlogic ARM Cortex-A9, Dual Core, 1.5 GHz |
RAM | 1GB DDR3 |
Internal Storage | 16GB |
Screen | 7 inch Capacitive Touchscreen (multitouch 5 points) 1024*600 High-resolution ( TFT not IPS if I'm not wrong) |
Camera | 1 Front Camera 0.3 MP |
External storage | MicroSD up to 16GB (but I suspect up to 32GB to be tested) The micro card slot is located on the side of the table not have to open the rear cover. |
Gravity Sensor | Yes |
GPS | No |
WIFI | Built-in Wifi IEEE 802.11b/g/n 11Mbps to 54Mbps |
3G | No but support External 3G dongle or phone tethering of course |
Bluetooth | No |
Earphone Interface | 3.5mm |
Battery | 3.7v 3200 mAh Work Time: Up to 8~10 hours (manufacturer specs) |
Size | 197*113.5*10.5mm |
Weight | 290g |
Applications | Support APK installation Android Webkit,Google Search,Clock,File Manager,Gallery,Task Manager,Calculator, Calendar,OfficeSuite,Browser,iReader,Gmail, Skype... |
Inside the box | 1 x Ramos W17 Pro Dual Core 1 x USB cable 1 x Charger 1 x Userguide |
Manufacturer Website | Ramos Evolution Tablet PC - Buy Ramos Android 4.0 Tablet PC |
Rootable | Yes |
Price | On manufacturer site $138.99 USD |
Measurement
Screen
Web
Playing Videos
Gaming Test
A Video review:
