- Aug 4, 2010
- 1,505
- 110
APPLIES TO OLD VERSION OF GENTOUCH
This is what I am using. It's been a few weeks now and not one issue so far. You get Rooting and Clockwork Recovery in one shot made easy.
Author Specs and Instructions
Lincs Update.zip w/ Augen Patch v3
Summary of process:
Modified Gentouch78 software patch released on 8/22/2010 by Augen was copied and modified to include enhancements like the addition of Clockwork Recovery to make future software updates/flashes by the user easier. This process will also restore applications that originally came with your device such as Youtube, Talk, Gmail, etc. which will be removed by the 8/19/2010 Augen Gentouch software patch. This patch also adds features such as home, back, volume and control panel access buttons available onscreen, etc.
This update consists of a two step process.
Step 1 will apply the Gentouch software patch
Step 2 will restore applications that originally came with your device but was removed by the 8/19/2010 Augen patch. A Droid Pirate will also greet you hello upon boot up
Please read and re-read ALL instructions BEFORE you begin these steps.
STEP 1 PC HDD (C:\OS)
-Download the zip file: gentouch78patchv3-Lincs.zip
These are the files you will use IN PLACE of Augen's gentouch78patchv3.zip files. This patch includes AUGEN's update in addition to ClockWork Recovery. FOLLOW Augen's instructions (PDF document), using the files contained in this zip
You may view your device to see the enhancements made by Augen's 8/19/2010 software patch before you continue to STEP 2. You may notice missing or non working Google Apps. Step 2 will restore the Google applications.
STEP 2 (SDCARD)
-Download bootimg-su-googleapps-hosts-pirate.update3.zip. Copy this zip to the SDcard. No need to rename this file as it can be installed AS IS.
-Power down the device
-Boot into Clockwork Recovery (holding down the HOME button while powering up the device)
-Select install zip from sdcard
-Select choose zip from sdcard (it may take a min or so for clockwork to mount your sdcard so if it says no sdcard present just wait and try again)
-Select the zip file you want to flash.
-Once completed reboot
-Enjoy the new features!
Please note: By following these series of steps, you agree to and assume full responsibility for ANY and ALL repercussion, whether positive or negative. These instructions are supplied as educational materials only. Please use these instructions with only the files mentioned above! Again, the 8/19/2010 Augen Gentouch software patch was pulled from Augen's download area but this contains a copy of that patch. DO NOT mix and match versions of files unless instructed to do so.
Features for bootimg-su-googleapps-hosts-pirate.update3.zip
Apps removed from /system/data
AndExplorer.apk
AndroidPdfViewer_1_0_0b.apk
com.skype.android.lite.apk
DroidLive205.apk
fringAndroid.apk
Hi_MSN_6_0_5.apk
iReader.apk
quickoffice.apk
StreamMediaPlayer.apk
Apps added to /system/data
3D.Gallery.apk [NEW]
CustomLocale.apk
Development.apk
Email.apk
GlobalTime.apk
Gmail.apk
GmailProvider.apk
Maps.apk
MarketUpdater.apk
RotateD.apk
SettingsProvider.apk
SpareParts.apk
Superuser.apk
Talk.apk
TalkProvider.apk
Vending.apk
YouTube.apk
Other items
boot.img with /cache fix Updated my boot.img. this update.zip now has a working /cache fix.
root access
pirate andy
hosts file to block some ads [NEW]
More Powertool Apps to use here
More Powertool Plus Apps to use here
Follow this how to install Step #1
These are not from AuGen but it works. There is a program also but I disable that using IOBIT Advanced System Care Free | Pro [Startup Manager].
Just use the USB driver that only shows in the Device Manager when you connect your Gentouch to the PC.
USB Drivers 32-bit for Windows XP/Vista/7
USB Drivers 64-bit for Windows XP/Vista/7
Summary of process:
STEP 2 (SDCARD)
AndExplorer.apk
DroidLive205.apk
fringAndroid.apk
Hi_MSN_6_0_5.apk
iReader.apk
quickoffice.apk
CustomLocale.apk
Development.apk
Email.apk
GlobalTime.apk
Gmail.apk
GmailProvider.apk
Maps.apk
MarketUpdater.apk
RotateD.apk
SpareParts.apk
Superuser.apk
Talk.apk
TalkProvider.apk
Vending.apk
YouTube.apk
Other items
root access
pirate andy
