noelani77
- Oct 22, 2011
- 6
- 6
DISCLAMER: I'm not recommending anyone with this tablet to try and change your original ROM as there's no way to revert back to the original system... But for those who already tried... at least here's something to get it back working again... I also don’t know if it’s compatible with Flytouch II tablets, but I know the FTII ROMS did not work on my tablet. SO PLEASE BE CAREFUL!
Good luck
Aloha everyone,
Just wanted to share my experience with trying to upgrade and change my original ROM with that of FTII firmware.
TABLET STATS:
Model: SAWEE Pad
Firmware: 2.1-update1 V2.3:#3529
Baseband version: Unknown
Kernel Version: 2.6.32.9
infotm-sqa@infotm-sqa-desktop#71
Build number: ERE27
boot screen 0.6.3.1 (626)
Well like others here, I tried to upgrade my system only for it to get stuck.. I must have gone through at least 7 different ROMS and 20+ flashing, but nothing seemed to work and my tablet was unusable.
My first attempt was froyo 2.2 rom This ROM killed my restore partition and I ended up with a Zsys error in recovery. The install seemed to go through alright even saying it was a success but wouldn’t boot past the green screen.
Second attempt was 3656. Which I received “Error this wrap is not for current product!”
Third attempt was 3425 Just got stuck on Android_ and won’t boot.
Forth attempt was 3925 (iCan update) while this ROM loaded my g-sensor off (horizontal was vertical and vertical was horizontal)
Fifth attempt was 1170 update zip and Success it booted, but it required registration which I didn’t have because I didn’t have a FTII.
Updated to 1568 and 1623 which were both successful. My build stated deb 1568 and deb1623 but still required registration L and 3425 just won’t boot.
So I decided to dismantle my tablet. This is what I found: INfotmic Imapx200 Board WWE101 v3.5... 2 gb/256 ram 2 TF slots 2 USB Slots. And continued my search:
Then I found this ROM.. I believe it’s the original ROM for Flytouch III Sawee Pads and Since I had nothing to lose I downloaded it and SUCESS! IT works J
www.******** 9v_600.rar Deposit Files
Flytouch Recover ROM flytouch2-ROM-recover-card.zip
I formatted a SD card using the Flytouch Recovery ROM/ created a folder in the sd card with a folder called Android and copied the ramdisk.img, sytem.img, uboot.nand.bin, UImage, userdata, zsys and 9v_600 into the folder.
Put the flashcard in the upper TF slot and press power. You should see kernel-******, ramdisk android/system android/zsys being copied and extracted. Then you’ll see a screen that says "Burning the filesystem" (I got Recovery now!) Remove the SD card and with my superpad it automatically reboots itself.
You should see an infotmic screen, next a penguin in left corner and white "android_" after a few minutes (be patient) a silver ANDROID Logo should be visible and next the calibration procedure.
If not, try the recovery mode by pressing and holding HOME + ESC (front round button) it says something like "press the required keys if you want factory reset" release Home+esc and press them again. The recovery should start followed with burning the filesystem again. If it still doesn’t work reflash again. The flashing sometimes doesn’t work; which could be a bad card or reader. But it works..
Cons:
My camera doesn’t work. I'm not sure if I messed it up when I took it apart, or if it’s the wrong uboot.
The battery seems to drain quicker.
And I haven’t tried the market yet, no wifi where I live L
New Specs below:
Model : sawee10
android version 2_2_20110430
Kernel 2.6.32.9 semitime@semitime-server #2
build: frf85b
Good luck
Aloha everyone,
TABLET STATS:
Model: SAWEE Pad
Build number: ERE27
Cons:
New Specs below:
Model : sawee10
build: frf85b
