OK, I'm a bit (?) confused...I have installed a microSD card (8gb, Fat32) into my A500...Now; How do I use it? How do I transfer files and so on to the card? I have been using a file explorer program but when I select the card, it shows the main A500 directory (I think)...Hope the question is clear enough...Thanks,
Steve
Steve
