maistro112003
- Jul 7, 2012
- 2
- 0
Hi To all
I bought a Chinese tablet called Xtouch,and that's the link to it
X906_Xtouch | touch the world
it.s on ICS.
and i have some problems like the volume buttons work as "Back" & "Home" although there is a back button,and the Specs said it has a GPS and i tried many GPS programs but it doesn't work,
I mean the programs works fine but there is no signal at all no matter how long i let the GPS on, in the other hand a program like "android assistant" reads The GPS sensor.
so i though it must be a software default, and tried to download the firmware from the site but i can't start the recovery mode with the same way they explained in the video.
so PLEASE if any one know how to root this device or how to help at all,That would be appreciated .
Thanks in advance.
firmware version number : eng.neojet.20120326.160745
Android version : 4.0.3
Kernel version : 3.0.8 root@neo-jet#225
Build No. : DFP1008R 4.0.3 IML74K eng
neojet.20120326.160745 test-key
it.s on ICS.
Thanks in advance.
