Simple way to power off Lenovo IdeaTab A2109A?
ardentblue
Mar 20, 2013
61
I want to quickly and positively power off my A2109A. Is there an app that acts as a power button?
I have been able to turn it off with airplane mode, I think. With a secret combination, I choose a setting, and the tab asks me if I really want to power off.
Otherwise, I seem to be stuck with the power button, which seems to suspend everything. I think.
Must be a simpler way...
** Root access to your phone is required to use this application. If you are not aware whether or not your phone has root access, you probably don't have root access. **
Um, is this a rabbit hole?
I see a number of power off apps, and they all seem to require... rooting.
Root app that will work on JB and A2109?
I'm sure it was in the super detailed user's manual, and I just did not see it for all the verbage...
To power your A2109 fully off, simply press and hold the power button down for about 5 seconds. Up comes a menu box (yes, Windows terminology) with the top choice being "Power Off". Choose it, you are asked "Your tablet will shut down", Cancel / OK. Tablet shows "Shutting Down", followed by the vibrator for @ 2 sec.
I'd blush, but in cyberspace, nobody can see it...
