SmartBook SmartPad UMTS - won't work after reset all settings.
hamerpl
Hello.
I've got a Tablet - SmartBook SmartPad UMTS with 3G modem inside and Android Froyo 2.2 - it has also Tegra 2 chipset inside.
The problem is i can't boot tablet it stuck on black screen and nothing more.
I do a hard reset setting tablet then tablet turn off and i can't boot it again.
There is any solution to hard reset (key combination) or other idea?
There will be a trick when the tablet boots to put in newer Android version ? Like Gingerbread or even ICS. (running Tegra 2 so i think its possible)
The factory of this tablet does not give any support...
I pray to found way to turn on this ****.
Sorry for my English.
Kind Regards.
System operacyjnyAndroid OS,v2.2
Wyświetlacz10.1“(25.7cm) TFT,rozdzielczość 1024 x 600, multi touch(capacitive with 4 points)
ProcesorNVIDIA® Tegra™ 250 chipset, 1.0 GHz
Pamięć RAM512 MB DDR2
Pamięć ROM512 MB, SLC
Sensor ruchuG-sensor
WLAN802.11 b/g
BluetoothBT 2.1+EDR
Kamera1,3 Mio Pikseli(przód)
Porty I/O1 x złącze dokujące(30 Pin), 1 x Gniazdo słuchawek mini-jack 3,5 mm, 1 x USB2.0,
1 x HMDI, 1 x microSD™/ 1 x SIM card reader
BateriaPolymer 3300 mAh, 7,4V
