SOS!!! Need HELP ON MY HUAWEI IDEOS S7!!!!!!
vernon15
8
i was trying to move the framework apk from the system folder (internal memory) using Root manager and copying it to my sd card BUT, SOMEHOW i accidently deleted the original framework apk causing my tablet s7 to crap on me.. And now Nothing happened, nothing moved, wont boot to homescreen, black screen NOTHING!!!!!!!!!!! I CANT DO anything :(
But im new to android, (1month) and its my first and probably the Only android tablet ill be getting :\
So can anyone help me get it back to its original factory settings please!!!!!!!!! :(
Did you manage to copy the apk???
I did the same thing and ended up bricking the tablet,
Had to use the tegra tools too Format and restore,
Do a google search and see if you can find the framework apk file,
Also try recovery menu first and try a restore which will erase everything on the tablet but at least it will be working again...
How do you format the device bro..? And yeah the framework.apk is copied to my sdcard, but how do you move that to internal memory?
Or format the device
So far huawei ideos s7 doesnt support recovery menus .. So i tried that, and failed...
Try with pressing Menu, Send, and power buttons together for a while and see.
I can find 'send' .. I tried volume +, power button.
Goes all glitchy then Comes up with a black screen....
But is there a program out there for formating the s7? From the computer? So i can reset to factory setting..
Sent from my huawei ideos s7-105
Menu, power, and send buttons.
Send button is the green colored answer button on the righthand side.
Sent from my IDEOS S7
Well same result... Black screen.
I got the normal default rom, not any custom roms...
