Hi Guys, I have a superpad3. Everything works just fine except when I charge the battery for long time (24 hours) it is stopped at 57% even when I continue to charge it. I tried to discharge it and leave the battery drained and then charge it again for long time, but I still have the same issue. Is there any solution for this issue? Is installing a new firmware can solve the issue? If yes, from where I can download it? the specification: Infotmic ARM11 1GHz, 512MB DDR2 Memory, Google Android 2.2, 10.2" SCREEN 1024 x 600, 8GB built-in, 2 Ports USB2.0, 1 x Mini HDMI 1 x TF card slot 1 x DC jack Battery Built in 6400MAH WIFI,802.11 b/g, 3G(WCDMA,EVDO) Waiting for your help guys Thank you
