I got the Newest tablet the T410. After installing IHeart radio, my device freaked out. It aparently needed a firmware update, did that ok, done right> Oh not so.....
I had to reinstall IHeart and other apps because I had to do a FACTORY reset, which really made me mad.
Now....the problem is...IHeart radio app won't install correctly.
Just today while I was browing the Internet, it suddenly FROZE up on a web search within Google. All esle failed so I had to scrimp around the internet to find a fix. You have to PRY the back off very carefully and unplug the little wires (Basically disconnect the Battery. I plugged it back in and BAM...back in business. I wanted to post this because I have never seen a solution to this specific problem. I think IHeart Radio app messed my new Tablet up. Hope it helps someone else.
