Tablet Does Not Go Into Firmware Installing Process
minthura
[FONT=&amp]Hi, I m looking for a solution for a china made [/FONT][FONT=&amp]8 inch tablet[/FONT][FONT=&amp]
[/FONT]
[FONT=&amp]I bought it from street shop and not from a site but i believe it is identical with the one from the link shown below
[/FONT][FONT=&amp]http://chinaphonehouse.org/2011/04/epad-2-via-8650-en-8-pouces-%E2%80%93-look-mini-ipad/
[/FONT][FONT=&amp]Here is my problem, relating with uberoid installing[/FONT][FONT=&amp].
[/FONT][FONT=&amp]My tablet directly boots its original firmware instead of going into firmware installing process when using uberoid v12 .I desperately need to install new firmware because,although it boots up successfullly (i think) the launcher is hanging( showing black background).here,I can scroll down the status bar, rotate the screen, can also take photos(but nothing showing on screen just hear the shutter sound). I used uberoid tool.but it can't boot uberoid rom from sd card.It directly boots its original firmware..What should i do???
Any suggestion please!!!
IT is china made[/FONT][FONT=&amp] 8inch[/FONT][FONT=&amp] tablet looks like 3g i pad(with antenna cover on upper part of back).screen resolution unknown.when operating,led is green,when charging led is red. audio port is black..It has power button,volume+ - buttons,and back button.Help me plz..[/FONT]
