Tablet Idle, Battery Consumption 80%
Deanz_D
Ok so i got myself a netpad evo w5... The battery is 3500mah.. My friend said it is good enough and it should be able to last around 2-3 days but my tablet always run out of power at least twice a day even when i rarely use it.. And when i check the battery consumption, it show that tablet idle use 80% of power.. So can anyone help me to make the consumption lower?? Please!!!
It's very likely something happening in the background and there are lots of possibilities. I suggest you install an app from the Play Store called Auto Airplane Mode (by DON). I think that would probably solve the problem.
Your tablet is not nexessarily inacrive, despite being asleep. This will automatically take care of it.
