Touchscreen problems!!!
stevehdevos
Hi everybody,
Does annyone knows the solution regarding touchscreen problems with Samsung Galaxy Tab? I have loads of apps I can't use due to this problem.
HELP.
Not sure what issues you are referring to. I have used 2 G-Tab versions, and have not experienced touchscreen problems with specific apps. Are you using a screen protector? If so, that might be the problem. A screen protector isn't really needed on the G-tab because it uses gorilla glass. Otherwise, it might be helpful to be more explicit about the specific touchscreen issues you are having.
