Hi,
I just bought a V712 Onda Tablet today and love it. Except for one thing. The sound has something wrong with it, it keeps scratching or ticking almost like some kind of codec problem. It´s uneven intervals and seems to be worse with low quality files although none of my other android devices has any problems with it and it can still be heard on FHD files. Wondering if this is what Ainol fire users are calling popping? I can hear it through both the speakers and headphones. High pitched and makes it impossible to watch or listen to anything since it´s simply too disturbing.
Does anyone have any idea of a solution for this? Best one I´ve found was a general android solution of dissabeling dolby surround but that setting doesn´t exist on my tablet. I´m not sure which one is the firmware line but I´m guessing it´s the build number? If so mine is ICA.g12refM704A1.20120828 does this mine I´m running 1.2 firmware?
I can return the tablet (last one they had) but if so I need to do it tomorrow so any quick responses or ideas would be appreciated.
