Usb connection help for android epad
Birdman
17
Hi, I want to connect my epad to my computer using usb wire but I don't have the driver. Anyone know where I can get the right driver for it? google android 2.10 10inch tablet
Are you just trying to get it to show the contents of the internal storage? Did you mount the device after selecting from the notification?
I want to use the usb connection to transfer files to the epad, or sd card. I can do this using my usb key, but it would be nice to use the usb connection but I need to install a driver. (I know I can just plug my sd card to my pc, I do that) but it would be nice to find the driver.
go to the "zenithink usa" site and look for the flash roms. there are drivers that will connect up to the OTG connection on the epad
I don't know about you guys but this site Zenithink.us keeps giving me the run around trying to get any drivers/firmware.
