whe i connect a usb flash frive, keyboard, mouse, whatever, it simply doesn´t recognize it, can you guys tell me what can dooooooo.
Btw i´m using a coby kyros 8024 with andro 2.2.
you must change to USB Host mode so you can use your devices...by default its in USB Device mode. if you have a power widget its besides the Sun Icon..if you dont have the power widget go to Settings ->Advance Settings->USB BUS MODE(click this)
