Music
- Feb 5, 2011
- 571
- 7
I tried a few of the GPS provider apps to get my Nexus 7 to work with a couple bluetooth GPS receiver,a generic one, and a DUAL XGPS150, and most apps are working fine- the ones programmed to accept BT GPS data. I had the best success with the one from GG moblab and de.mobilej.btgps. If you use 2 receivers, then you have a different problem: you can't just switch over to the other receiver. You need to un-pair, re-pair, then switch over.
Apparently, some applications cannot use the information from a mock location app, or the System needs certain settings to changed properly.
Can anyone share their advice to properly set up the Nexus 7/13 to use a bluetooth GPS receiver? ThxZ
