Same boat here until October. I would like to keep using my current rom so I'm going to edit the supplicant.conf file. I also use the hydtec adhoc program from the market which simply copies a file to get this all to work and is good for the lazy people like myself. So far its worked on every tablet I've owned.
Howdy rsmcjr! Another Nook Color (her), gTab (me) couple here. I'm really curious how the UD ROM will work on the gTab...if you give it a try please let us know how it goes.i am looking at buying a GTab and i'm glad i found this thread. i bought my wife a Nook Color and it won't see an adhoc enviroment either, but i found that UD put out a CM7 based GB rom that has the adhoc fix built in and just noticed that they made a GTab version as well.... Viewsonic gTablet - The Ultimate Droid - Forums it works great on her NC so hopefully it will work as well on a GTab... so what do you think of your GTabs??? worth the money??
Jeff, last time I looked (it's been a month or so), "editing the supplicant" route on the Nook Color seemed to leave wifi a little wonky. I think people were having trouble with wifi turning on after sleep. Now first, this might be exactly how TNT Lite does it (I am clueless) but second, I was wondering if you've had that kind of problem with your tablets. I'd sure like to find a way around it for the Nook. (FWIW, it's not a problem for the gTAB.) Your thoughts?
-matt
ATM my wife is primarily using her NC as an eReader (go figure) so I haven't done much besides root it and get Google apps working. I really admire the screen and the compact size. But as a new gTab owner, it's clearly the better device for me: camera, microphone, USB slave+master, light sensor, etc. For just a few $'s more, the dual-core Tegra and the larger screen make me pretty happy. As you already know the viewing angles on the gTab are pretty meh, but it's a minor tradeoff.
-Matt
I'm glad you followed up...I appreciate figuring out what's happening under the hood.TNT lite in my opinion does it the best way but can leave wifi wonky (they added code so it will not ignore adhoc networks).
YEAH, exactly what ^he said!I would love to try the new UD 3.2 but want someone else to try it this time around. If anyone does make the attempt, please let us all know...I loved UD on my OG droid!
Jeff...ever-so-slightly off topic: I noticed my Droid gets pretty toasty when I use wifi tether (38-42 degrees C). Definitely hot/very warm to the touch. What's your experience like, and is that a concern?
-Matt
Running Pete's GB (GPA13). Max speed is 1000MHz, ondemand governor. Normally runs around 28-30C. I think I also have SetCPU set to switch to conservative at 50C.What are you clocked at and what governor are you using? I'm running a private release GB rom from Liquid and noticed that the whole rom runs that way unless I switch the governor to ondemand instead of interactive and scale the CPU back to 800-900 MHz. When I run my favorite rom which is UD 2.5, wifi tether doesn't affect the temperature a whole lot and I'm set to 1ghz using the interactive governor. Long story short, try looking at the CPU settings on your Droid.... You might have to change the scaling when tethering to keep the heat down. It has been said up to 80c is as high as you should go but I have mine set to go no higher than 50c to be safe.
For me, I hadn't even thought about adhoc when I installed TNT Lite. It was probably a day or two after, and I wondered, "Hmmm, will my Droid's wifi tether show up?" Sure enough, it did and worked great. Then I realized, "Oh, must be a supplicant fix in there!"
Here's the interesting part: you said "can leave wifi wonky" but so far, I don't think I've had any trouble on the gTab with wifi. I've tried two settings, either (1) on when plugged in, or (2) off when screen is off, and both seem to work fine. When I turn the screen on, either wifi is running (1) or about 10-15 seconds later it's reconnected. I haven't had to turn wifi on/off like I did with the Nook.
So the next step for me is to figure out why the combination seems to be an idiot-proof solution in my case (not that I'm complaining...I'd just like to know in case I switch ROMs). Any suggestions?
-Matt
Thanks for the suggestion, I'll definitely look at scaling back the speed. I have a bad habit of running Quadrant with new kernels at the high end, and then forgetting to set back CPU speed to something less severe. I think I ended up leaving the Droid at 1000MHz since the screen transitions and redraws (Launcherpro) have been perfect. But doesn't GB have GPU optimizations? If so, maybe 800MHz (which is what I was running rooted stock Froyo anyway) will be fine.
-Matt
