Looking at Galaxy Tab on Rogers (Canada) net. Important to us is the Wifi Hotspot function.
Is there a dhcp server that you can configure to give out specific client ip's, gateway ip and DNS ips? Or is the configuration fixed? Can your local pc's use static addresses?
Using the Wifi hotspot you can get on the the internet via the HSPA modem, but are there any problems communicating between local computers using the wifi hotspot (assuming you can figure out their ip address)?
Wireless hotspots like Verizon's Mifi are fixed and not configurable as best I can tell. Hopefully the Galaxy Tab will be ...
