WiFi Problem
ejannette
HELP ME PLEASE. I CAN'T SEEM TO GET ON THE INTERNET. ON MY ANDROID TABLET. I AM FOLLOWING THE INSTRUCTION AND IT IS NOT WORKING. I WAS ON :DVIA WI-FI THEN TURNED OFF AND NOW I AM UNABLE TO CONNECT.:mad: WHAT CAN I DO?????:mad:
Tap settings. Tap wi-fi. Tap menu. Tap scan. Find your internet connection. Tap connect. If it doesn't connect, tap "forget". Then tap scan again. See if this works.
Sent from my DROID using Tapatalk
Hello ejannette, congratulations on your new tablet and welcome to the forum. I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you. Good luck!
The advice Sherri gave you often works, I'd also suggest you give it a try.
