infinityplustwo
- Nov 22, 2011
- 2
- 0
Hi,
I'm new to all this, so I apologize for my ignorance here, but I have a WiFi problem after installing CM7 (latest stable, 7.1.0, mid-October build).
Thanks,
Infinityplustwo
- WiFi (home network) worked fine when I first started using CM7 on my Nook Color
- Installed a bunch of apps and was trying to learn the OS
- Somewhere along the way, my WiFi stopped working (says my AP is "out of range" - 6 feet from an 802.11n router)
- My laptops connect ok showing a strong signal (so it isn't my network)
- Re-entered my AP as if I were adding a new connection - this worked FOR A WHILE but later lost WiFi again
- Tried adding my AP again, did not help
- I've rebooted numerous times, this does not help at all.
- Removed my MicroSD card and booted in native Nook - WiFi works great. I've done this several times, WiFi always works fine with Nook OS.
- One of the apps I installed is WiFi Analyzer - it WAS showing absolutely no signals....but I just started it up again and all of a sudden I'm seeing about a dozen hotspots and I'm now connected to my network. (I've been putzing with this for 2 days without seeing any signal or connection, but now all of a sudden it is working.
Thanks,
Infinityplustwo
