Will a USB modem stick work with an Android Tablet ?
Best thing to do is google each USB modem,
Then after finding the brand/chip set to see if it will work with android
You have to find out if there is software to run the USB sticks. If not, you will need a hotspot device instead of USB.
I'm in the same process now. I have a USB 4G stick. I might buy myself a mobile router or go with a Windows tablet due to lack of drivers for the cellular modems.
If the tablet only has mini-USB port, then you need to get a adapter and have a try.
I also want to know if a usb modem stick work with an android tablet. so please let me know how it works, okay? :)[h=2][/h]
