Wireless headphones wont work?
JacobEugene
Jan 2, 2016
I connect my headphones wirelessly to my tablet, and the volume for the headphones doesn't activate on the device. The headphone volume and the device volume are counted as seperate, the headphones, when connected, can be full blast, but as soon as you disconnect them then the device's volume can be mute. Anyways, the volume will stay mute, and when I activate the volume by turning it up it is played from the devices speakers rather than my headphones even though every setup says its connected to my headphones with Bluetooth. I have had to use my 3.5mm Auxiliary cord for the past few days, and the restriction of it is killing me.
I am using Android 4.2
This is the type of headphones:
BT513 Beyution Wireless Headphones
I tried every solution on that site and nothing worked, I still can't get them to connect properly.
