WM8650 Help?
Joshcarr
Right then guys i bought a WM8650 and tried honeycomb ect.. extracted the files to my micro sd, plugged it in while my device was off plugged in it to the charger and installed uberoid, it booted got to the custom uberoid logo on the boot and just stayed there for 60 mins and turned off and now it boots up when a micro sd is plugged in with a os to install ut it just gets stuck on WM8650 android 2.2 is upgrading... is it fully bricked?
Its a WM8650 800mgz 4gb, green led, red led charging.
Help?
