My freshly purchased WM8650 10" sawee10 tablet has a problem reaching its external microSD card, most likely due to incorrect settings/mounting/linking.
Tried with 4 different cards (1-2GB), formatted as FAT and FAT32, .....no change
The 2 USB port working fine, they show up as udisk1 and udisk2 in file manager.
When I open a file manager, it lists 3 related directories in the MAIN / (root) : sdcard , sdcard1, sdcard2
When open directory "/sdcard/", it shows content of the MAIN /
When open directory "/sdcard1/" , it shows the content of the INTERNAL MEMORY, such as LazyList, download, Flash_Player,Android,DCIM,mobitibi, TunnyBrowser, .....
When open directory "/sdcard2/", it shows again content of the MAIN /
In /mnt/ directory there are 3 directories : /secure/ , /asec/ , /sdcard/
When I open "/mnt/sdcard/" directory, it shows contents of the INTERNAL MEMORY, LazyLIst, download, Flash_Player,......
Any apps I am downloading also goes to the INTERNAL MEMORY /download/
From my little experience with linux, I think the problem is somewhere in the settings/config file, how is the external microSD device is mounted (linked to a directory in a file system).....if remember, in linux the config files were called "fstab" and "mtab"
Could someone please provide info, how this can be done properly, and also which apps I need to open/see/edit configuration and init files ?
Thanks!
Thanks!
