Zepad 2.2 Help.
mark215
First I want to thank everyone who helped with the sd card recognition. Now, I need help with some other things/
1. How do I delete stuff from the desktop that I no longer want (Widgets)?
2. When I put a flash drive in the usb port how do I transfer stuff from there to a folder within the tablet...(New Folder) I created OR Music folder....same with movies to the movies folder.
3. Can the volume be adjusted while a video/movie is playing?
That's about it for now...I have no use for the manual that came with it except for kindling!
Hi!
You could try installing a file manager - I'd recommend you Es file explorer - you can cut/copy/paste/rename etc.
