zepad desperate help
pjay61
can someone please advise me i have just got this thing and i am having great difficulty with lack of sensitivity, there is no way you can go anywhere on it without having to litterally bang the screen, i managed to download ''angry birds'' to test it and there is NO way you can play any type of game like that, also when you are looking to scroll down a page there is NO way it is possible someone please help before i pull my freeking hair out, i have tried settings but there is nothing there about adjustment of sensitivity, HELP ? ? ?
Unfortunately, I don't have an answer but was wondering if you figured out how to fix that problem since you posted it? I just got that same tablet and I totally understand your frustration!!!!!
Hi!
What model Zenithink do you have?
Try calibrating the screen if you have such an option.
You could try also - factory reset and in a last case scenario flashing it.
(Of course, it could be that your screen sensor's defective)
heya - first reply for me!
I had same issue and used a DS stylus it responds much better, then i did the calibration reset in settings using it too (or any pen with a plastic lid TBH),
