9742 MBR problems and such post here.
Traveller
2,858
983
The 9742 can function with an external mouse using the USB adapter Coby provides with the 9742. So plug in a mouse and turn on USB debugging using the mouse, then connect the tablet to the computer and run the commands.
maboy
thanks Traveller1701 and Vampirefo, my camera still not working, I copied the file from 9742 stock.
now camera and touch screen is working, I rename the gt2005-2015.ko to gt2005.ko, because i can't configure it on the terminal.
more thanks to you guys..
redazteck
May 9, 2014
Hi, thanks for the great work that you guys have done here, i have managed to fix inverted touch screen(you know mirror) and camera conection problem, by following the instructions on this thread, now i am stuck with the wifi problem it just won't turn on, i have made a dump before flashing with livesuite the image provided here, can you please guys help me getting my tablet 9742-8 done! here is the link to the dump files, will you guys please point me on the right direction so i can get the wifi to work again?? link to the dump files: kiroz9742_dump thanks in advance!!!
