Hi there - I recently won this tablet at a school fair - its driving my nuts - the wi-fi connects and drops intermittently that is it searches and finds available wi-fi (home, work or other). My issue is that I connect, try to go to say google play store as an example, wi-fi just drops I then reconnect and try again sometimes it will stay up and I can connect, then it just drops. Signals are excellent /very strong this happens no matter where I am (home router has up to date firmware).
These are the specs any help would be appreciated as this tablet is useless until I can rectify this.
Ultra-thin 7 inch Android 4.0 MID tablet pc 512MB/4GB Q88 Allwinner A13
Operating System: Google Android 4.0.4
Screen Size: 7 inch
Kernal Version 3.0.8
CPU Type: Cortex-A8 1GHz-1.5GHz
Build number: Nuclear_q8_a13-eng 4.0.4 IMM76D 20120629 TEST-KEYS
CPU Manufacturer: ALLWINNER
CPU Model: A13
RAM / Technology: DDR3
RAM Installed Size: 512MB
Hard Drive Type: NAND FAST FLASH
Hard Drive Capacity: 4GB
PCMCIA Expansion: Micro SD Card / T-FLASH(Support 32G MAX)
3G: Supporting External 3G modem
Battery Type: Built-in Lithium Battery: 1800 mAh
Warren
Screen Size: 7 inch
CPU Model: A13
Warren
