data rescue help
poiupoiu
Evening! The device's display broke and I can't connect to the device through wifi. Does anyone have any idea how data rescue could be performed? I don't see a usb port on it either; should there be a dock present together with the device? I haven't it. Any ideas? Any specifics concerning wifi connection that I'm overlooking? Thanks in advance. Edit: in general, what are some of the ways data rescue could be performed under extreme conditions and what factors would absolutely prevent it? Many thanks.
Frederuco
Super Moderator
1,978
503
If you have a miniHDMI to HDMI cable, you can try hooking to a TV to use the tablet.
You can also hook your tablet via the charging cord (unplug from the wall wart and there is a USB) and a computer. Then you should see your tablet as an MTP device and can get your files.
If you happen to have USB debugging checked, have a look here on how to backup your tablet: http://www.transformerforums.com/fo...ckup-unrooted-android-4-0-4-1-4-2-device.html
Also, you can do a file transfer so you can see your photos and files if you have USB debugging enabled: http://www.transformerforums.com/fo...017-guide-how-recover-data-locked-tablet.html
julianwill
you should have some usb cable which allow you to connect the device to computer.
you may also check whether there's a memory card which you can take out and connect to computer.
