help plz
amyjo
i have the superpad III it was working fine now green light comes on and i have totally black screen i just got case and keyboard problem seemed to occur after plugging it in plz help:mad:
J
jimbo7630
Guest
oops, sorry, ask Spider to move your thread to a Forum where more people can help.
amyjo
im new here tried posting n a forum didnt seem to get help lol who's spider
J
jimbo7630
Guest
Spider is the big boss in charge of thread relocation, just holler and he'll come!
Spider
15,783
1,813
Hi amyjo, congratulations on your new superpad III and welcome to the forum. I'm moving your thread to the Gome Flytouch II Variant 2 section for you, where more people with your tablet are likely to join the discussion and try to help you. Good luck!
leeb
463
21
First things first...
The charge light... does it start out red THEN turn green or is it just green all the time?
1) green all time... Give it chance to CHARGE COMPLETELY... the light should go OUT (possibly change color).
2) starts (red/whatever),turns green... Have you disconnected the keyboard yet? On the lower right edge is a itty-bitty button. A.K.A RESET... use your stylus to press it after you disconnect the keyboard... more than once is okay. THEN try to bring it up WITHOUT the keyboard.
Hope this helps! :D
