It won't start up ! I charged for about 7 hours. When I press the power button - -
Petronella
It won't start up ! I charged for about 7 hours. When I press the power button - - all I get is a brrrrr sound and a blank screen. I have followed all the instructions in the 'manual' to the letter !
{ I am an older granny.}
My Android is a 7inch MID which was bought about 6 months ago and only now have I the time to use !
Build No. is WMT2.0.1_105
Kernel Version is 2.6.29-00236-g4f8dbbb-dirty
Firmware is 1.6
Model No. is Generic
Memory Size is 256MB
Can somebody help !!
Spider
15,781
1,812
Hi, welcome to the forum. I'm moving your thread to the Android Tablet Q&A section for you. hopefully, someone there should be able to help.
Tabletuser23
Whoa 7 hours??? I think its overcharging this happened to my friend too Maybe you should go to where you've bought that and ask help
BEDSHOP
hi
i had a similar prob where a virus had altered my screen settings to zero ,the tablet was working but the viewing area had been reduced to nil/zero.i cured mine by re flashing then installing a good free antivirus package.
no idea where you will find rom to reflash .
cheers
