Analogous to "turn on"/"turn off" or "use"/"don't use" or "active"/"inactive"What does "mount" and "unmount" do please?
Just another obscure and obtuse compterese term.
that's also the weird thing: when I insert the card, the settings>storage goes from saying "insert sd card for mounting" to "mount sd card," but when i touch mount sd card after the card is installed, it has always done nothing, or sometimes the internal storage will say "calculating" but then just goes back to it's previous state. The external sd card doesn't mount or say "mounted."
Does this mean the hardware is bad if it recognizes an sd card, but won't mount it?
hmmmmmm, I understand about 13.67% of that. is this something I can do with EASUS (sic.) to rewrite the partitions. and how should I set them?
It seems some of this may be getting in over my head.
