guys can anyone help me with this big problem abount my s7 tablet????
M mclowell Member Apr 13, 2013 3 0 Apr 13, 2013 #1 guys can anyone help me with this big problem abount my s7 tablet????
vampirefo. Senior Member Developer Nov 8, 2011 3,836 1,394 Apr 13, 2013 #2 most likely you need to do a factory reset.
M mclowell Member Apr 13, 2013 3 0 Apr 14, 2013 Thread starter #3 vampire how can i reset my factory settings??? can u help me please??
vampirefo. Senior Member Developer Nov 8, 2011 3,836 1,394 Apr 14, 2013 #4 How to Hard Reset Huawei Ideos S7 Slim Tablet ? : Android World
M mclowell Member Apr 13, 2013 3 0 Apr 15, 2013 Thread starter #5 thx so much master vampire i really appreciate ur big help to me......... thx you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
S sky_finder Member Apr 13, 2013 4 0 Apr 16, 2013 #6 vampirefo. said: How to Hard Reset Huawei Ideos S7 Slim Tablet ? : Android World Click to expand... Dear Bro Could you please help me bro I try this but not work for s7-105 Even I try to flash the set but I don't have the firmware and the steps... Also in the forum many link is not working Could you please help me to fix this problem Pls look here bro http://www.androidtablets.net/forum...56987-google-account-lock-idous-s7-105-a.html Pls help me bro Thanks.
vampirefo. Senior Member Developer Nov 8, 2011 3,836 1,394 Apr 16, 2013 #7 http://www.hard-reset.com/huawei-ideos-s7-hard-reset.html Try this.
S sky_finder Member Apr 13, 2013 4 0 Apr 16, 2013 #8 vampirefo. said: Huawei ideos s7 hard reset - PDA Smartphone PNA hard reset soft reset Try this. Click to expand... I have tried on this bro. Could you pls advice me to flash the set.. If you have the firmware pls give me bro or is there any other way to reset the google account bro thanks
