No sound on hdmi.
Tinozaure
HDMI Audio not working.
Hello
I have a A2109A with last build I think from Lenovo : A2109A_A411_03_13_121126_GE.
It appears that hdmi audio is not working.
I tested with 2 different micro-hdmi to hdmi cables on 2 differents TV.
I read some posts here and it says to "shove" the cable in. I think I did but with no sucess.
As I plug the micro-hdmi the sound from the tablet is off and screen is mirrored on TV.
By the way I had no success in playing video on TV alone using VLC and xbmc.
The settings are ok but no sound at all on TV.
As soon as i unplug the cable the sound is active on the tablet.
If you can give me some hints before I contact Lenovo for guarantee service.
Thank you.
damianiw
27
I had sound working (maybe check your audio settings in xbmc) I don't recall playing with it but my last Sony TV would only accept pcm over HDMI
I have found I get white dots and specks over my output though, I only have one cable which worked OK with blackberry playbook
Sent from my IdeaTabA2109A using Tapatalk 4 Beta
Spider
15,783
1,813
With my tablet and TV, the tablet has to be plugged in and on before I switch the TV to HDMI input.
