Problem Downloading Apps
leeshor
6,329
1,037
Welcome to the forum
You left out some information that may help. If you are trying to install them from the Google Store the quickest solution may be to remove your Google account, restart your tab and add it back. Nothing will be lost doing that.
Spider
15,783
1,813
Hi dgfaze, congratulations on your Tab A500 and welcome to the forum. Glad you decided to join us here at Android Tablets. The solution suggested by leeshor is definitely worth a try.
