Questions Not Being Answered
valerie.pharr
21
I've been a member for of this site for awhile now and I'm still not finding it effective. Could someone point me in the right direction please?
J515OP
Super Moderator
5,172
899
Hi valerie, it helps if there is an actual question. The more details you can provide the better. Also check forums specifically dedicated to your device and try the search feature. There are plenty of people here willing to help but first you have to help yourself and also have patience.
JP
Spider
15,783
1,813
Hello Valerie, welcome to the forum. I'm sorry to hear you're not finding the forum effective, but I'm not sure what can be done to fix that. Your posts appear to be in the correct locations and it seems people try to help when they can. If no one answers a question, it's probably because no one who's looked at your questions knows the answer. I'm moving your thread to the http://www.androidtablets.net/forum/site-comments-suggestions/ section for you, hopefully someone there will join the discussion and be able to suggest something to help you. Good luck!
