I set a screen lock PIN and it works. But now I would like to remove it and leave my TF-300 screen unlocked. I went to settings but there are no options to change or disable my PIN screen lock.
How can I get rid/disable the screen lock completely? I can't find any thing in settings security do do this.
Thanks in advance.
Thanks in advance.
