Hi, there has been an update released for both Buahn tablet models, I'm just putting this here in it's own thread so it's easy to find for tablet owners, rather than asking questions and sifting through threads. It's a reposting of existing information others have found.
Tempo Australia is the authorised service agent in Australia, they release the updates in Australia and host the files.
Here is the link for the AMID 971R tablet update.
AMID-971R Software Update
Here is the link for the AMID 972XS tablet update.
AMiD-972XS Software Update
I found it best to open the link on PC so it was easy to view on screen whilst also doing it on the tablet. For the 972XS, after restart, the custom flash 10.2 was gone and I could not find flash 11.1 on the market so I copied it out from my phone to the PC, then into the tablet and installed it that way.
I had already updated the 971r to flash 11.1 and that was still intact after update.
BTW, TouchPal Keyboard (free) from Google Play makes things easier once set up properly because you can type into your browser a web address and hit the go button instead of searching via Google. For browsers on Android, so far, the best I have used is Opera Mini.
Do the update BEFORE you ROOT the tablet. I returned my 972xs because it had a screen issue. I updated the replacement, now rooted also. The root app did get stuck at a prompt where it says that can happen and I left it a while then unplugged the USB and reconnected it, then the root completed ok.
Flash player is too large to attach, but it can be downloaded online, I had a google for it and found a link straight away.
I have the Adobe Flash Player 11.1_11.1.111.10.apk version in my tablets and it works in both.
http://win-droid.blogspot.com.au/2012/08/android-flashplayerapk.html
