Acer A200 USB Verizon Air Card
Frederuco
Super Moderator
1,978
503
"Is there a way to use my Verizon USB Air Card in the Acer A200 USB port"
The only air cards that may work with Android 4.X are ones with a Huawei radio. If it does not have that, there is a very slim chance it will ever work because off drivers.
You could see about getting a MiFi device if you are eligible for an upgrade.
JWAYAD
Sanitary SOLUTION! Take your WiFi hot spot with you. I purchased a CradlePoint CTR35 Wireless N Portable Router for $48.00 from Amazon.com. Now all systems work the way they were designed to work with my Verizon 551L USB data card. The 551L plugs into the CTR35 USB port and supports up to 10 devices.
