An issue that seems to have appeared recently (not sure how long to be honest) is that my tab has to be turned off to charge. If I connect power when it's turned on a small red "x" appears over the battery icon where the lightning bolt normally is. The tab definitely recognizes it's plugged in because the red "x" appears or disappears when I plug or unplug the power.
If plugged into the PC there is also a message about being plugged in as a storage device but I can't find anywhere mentioning charging in the settings.
Any ideas?
Cheers
Paul
Any ideas?
Cheers
Paul
