I can't figure this out, baffling me.
I have the Nook Tablet 16Gb BNTV250 with OEM wall charger & USB cable.
On stock Nook & unofficial CM7's/CM9's roms, the OEM charger/cable works fine.
I can have max brightness, WiFi on, volume max, watching NetFlix with low battery and the charger will charge it pretty quick/normal.
Now if I'm on any CM10's rom, I can't charge the tablet while it's on.
It will show that it's charging but it will drain instead.
Doesn't matter if I turn off WiFi, lower the brightness.
It won't keep up and just slow drain battery.
Only way to charge it is to turn it off and it takes ALL night to get to full.
It feels like as if it's being charged by USB to PC, slow slow slow.
I know it's not the OEM wall charger and USB cable. As I've said, stock nook or CM7/9 charge fine.
I can't find anything on this problem...
