Trial_Test
- Mar 9, 2013
- 1
- 0
Hello.
I did not know where give it.
Recently i bought the Creative Ziio 7" 8 GB. I bought used from a person.
For a time i was used normally. After some time i decided reset the factory settings.
I chose Menu->Settings->Factory settings and i tapping reset the tablet.
Tablet power off and started again.
Then as always showed up logo "Ziio" and then logo "Zii powered" and
system stops loading.
I bought micro sd card company "no name" and micro sd card reader company "SIYOTEAM",
and format the card in system fat32.
Then i downloaded ziio firmware from manufacturer page to my computer and i then
have uploaded ziio firmware to my sd card. I insert the micro sd card to my tablet
and i turn on my tablet with pressed button "+".
Then showed up logo "Ziio" and appeared statement "Searching SD card Attempting to locate valid installer"
and then showed logo "Zii powered" and system can't load.
I've tried different versions of firmware from manufacturer page and further shows up the same statement.
Every time on micro sd card appears themselves file ziilabsinstallog.txt and in the this file
the log of:
is_disk_mounted( mmcblk_sd )
is_disk_mounted( mmcblk_sd ) : 1
search_and_install( /sdcard, /sdcard/NORflashed, 0 )
ERROR : dir /sdcard no installer found
search_and_install( /sdcard, /sdcard/NORflashed, 0 ) : -1
I have no way connect tablet to the computer because at time damage to tablet
i had turned off the debug mode.
I have no way get themselves to options such as "root" and "recovery".
I even tried Uberoid and CMW and further no effect.
Even does not work android safe mode.
Please help to me!!!
the log of:
