bocabean
- Dec 10, 2012
- 12
- 0
I rooted my Galaxy Note 10.1 about a year ago. I want to bring it back to original unrooted factory settings. I assume that I need to remove the following apps:
SuperSu
SuperUser
Titanium Backup
Triangle Away
I ran the triangle away program and now when I hold down the power and volume down buttons until I get to an Odin screen, it appears that I have no counter problems, it all shows "official", which I guess is good.
I am not sure what steps I need to take next. Should I be uninstalling the above software in any particular order? After that, how do I go about getting the original stock software reloaded again? There is nothing critical on the device that I am worried about from a backup point of view and I know that I can have all of my apps recovered from Google Play.
Any advice will be greatly appreciated.
SuperSu
SuperUser
Titanium Backup
Triangle Away
