Have you loaded the USB driver for the tablet on your PC?OK. Admission time - I figured out that I mistakenly added 2 movies to the tablet memory. Once I moved them to the SD, all is good. I'd still appreciate advice re: connecting the tablet to the PC. Thanks.
I haven't been able to access any app other than Google Music from the lock screen, anyone else have any luck with anything else?How about access an app from the lock screen or customizing the launcher.
Go buy a tick in LOTTO - in other words yip.I haven't been able to access any app other than Google Music from the lock screen, anyone else have any luck with anything else?
I have the impression that we did not get a customizible launcher, is that true?
What?Go buy a tick in LOTTO - in other words yip.
But as a whole I don't seem to have a problem.
What?
Have you turned on Bluetooth as well? Turn off the GPS - if you don't need it. Dial back the Display brightness.Icebike reckons one should leave the WIFI active in sleep. I don't let my tablet sleep unless it is plugged into the PSU. As so far I haven't had real problm .Battery life seems to be an issue (that or it's bad timing in the life of my battery). I'll pull it off the charger (at 100%) use it for 20min to check email, play a card game, surf and it will be at 82%. Then I'll put it down for an hour or 2 and when I pick it back up, it's 45% or under.
According to the tablet, nothing is running to suck up the juice.
I'm wondering if there is an easy fix or is this a warranty call.
Kinda figured.Sorry you didn't get my attempt at humour. You got it right there is no customisable launcher available on ICS unless you want to root your tablet.
Bluetooth: always on/ GPS?. I thought someone said they're all in the same chipset so never turn any of them off (BT/GPS/WiFi). Brightness is low and mine never sleeps. Still can't figure it out.Have you turned on Bluetooth as well? Turn off the GPS - if you don't need it. Dial back the Display brightness.Icebike reckons one should leave the WIFI active in sleep. I don't let my tablet sleep unless it is plugged into the PSU. As so far I haven't had real problm .
Kinda figured.
It is typical for the wifi and bluetooth to be on the same chipset but the GPS is often on its own. In any case having them on the same chipset doesn't mean they have to be all on or all off. Keeping the bluetooth and GPS off when not in use can lead to big battery savings. Also setting the time out to a short time will help conserve battery.
You say according to Android nothing is sucking up that juice. Where did you check? Did you look at the battery stats? What was listed there? Did you also check the apps to see what was using processor?
A battery app or app monitoring app could give you more details on what is actually running and taking up juice since the built in ones are sort of generic. You should see a big improvement by turning off the bluetooth and GPS though. Also why does your tablet never sleep? Are you saying you have set it to not sleep or it just never times out when it is supposed to?
